2nd Gen Durango 2004 - 2009
Radiator Fans kick in Temp Modification
Old Aug 14, 2011 | 05:47 AM
shahzammss's Avatar
shahzammss
Default Radiator Fans kick in Temp Modification
Hi all
I have installed the 180 t-stat & its perfect keeping temp low. But the cooling fans still starts @ predefined temprature. in my cas they never start untill i turn A/C ON or Temp reaches 195+ low & high when goes above 210+. is there a way i can reprogram fans to kick in earlier. what tool/device & how to do it most appriciated.
its 2008 hemi AWD.I did not install e-fan. it has only 2 e-fans & 1 mechinical fan..
Thanks
Old Aug 14, 2011 | 08:24 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You will need a tuner such as Diablo Sport Tuner or SCT. I do not think there is any other way, but maybe someone else would know for a difinitive answer,
FF
Old Aug 14, 2011 | 12:35 PM
jasonw's Avatar
jasonw
Site Moderator
I could be mistaken, but I do not believe the SCT has the ability to change that. The Diablo might.
Old Aug 14, 2011 | 09:50 PM
IndyDurango's Avatar
IndyDurango
Once it is out of warranty, direct wire it to your own controller and do whatever you want with it. Under $150 and 2 hours max.
IndyDurango
Old Aug 15, 2011 | 02:15 AM
shahzammss's Avatar
shahzammss
Thanks all
@fascist
which diablo tuner. on diablo site, there are so many
@indy
last month the warranty ended. i did not got you. which controller? $150?
please provide details for controller & procedure
Old Aug 15, 2011 | 09:00 AM
IndyDurango
The Flex-a-Lite Part# 31165-VSC would work fine.
http://www.flex-a-lite.com/auto/html...cessories.html
I am looking for something more finite adjustable however the same controller is what I run now and its fine for everyday stuff. And as for installation, it is easy. Real easy.
$99 on line.
HTH,
IndyD
