2nd Gen Durango 2004 - 2009
Crazy Codes, Please help
Old Sep 2, 2011 | 02:52 PM
Scottsjostrom's Avatar
Scottsjostrom
Exclamation Crazy Codes, Please help
2005 Durango, 4.7, Limited, 4x4.
Having crazy codes lately.
P0070 and U1120.
The ABS sensor and the Transaxle Control Module.
These codes came after I went out to start my Dodge and it didnt even turn, Dead. Jumped it and thought i may have left a light on, but the next day, went out to start it and dead. SO im thinking something is drawing power.
Does the ABS sensor or Transaxle Control Module draw that much power to drain?
And where is the Transaxle Control Module..
Please help
Old Sep 3, 2011 | 01:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
I don't show a P0070 on my list. I do have P0068,P0071 and P0072. Here some information on the other code U1120.
U1120-LOST WHEEL DISTANCE MESSAGE
When Monitored:
Ignition on.
Set Condition:
The PCM doesn't receive a wheel distance message from the Anti-lock brake Module or FCM (NON-ABS) over the CAN C bus. One trip fault.
Possible Causes
CAN C BUS CIRCUIT OPEN OR SHORTED
ANTI-LOCK BRAKE MODULE
POWERTRAIN CONTROL MODULE (PCM)
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Theory of Operation
The PCM receives the vehicle speed signal over the CAN C bus from the Anti-lock Brake Module or FCM (NON-ABS).
1.ACTIVE DTC
1. Ignition on, engine not running.
2. With the scan tool, select View PCM DTCs.
Is the DTC Active at this time?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
2.U0121-LOST COMMUNICATION WITH ABS MODULE/P0141-LOST COMMUNICATION WITH FCM ALSO SET
NOTE: If the vehicle is not equipped with ABS the VSS signal will come from the FCM.
1. With the scan tool, read the appropriate module for DTCs.
Is the U0121-LOST COMMUNICATION WITH ABS MODULE/P0141-Lost Communicate With FCM also set?
Yes
Perform the appropriate diagnostic test.
Perform the POWERTRAIN VERIFICATION TEST.
No
Replace and program the Powertrain Control Module per Service Information.
Old Sep 3, 2011 | 01:57 PM
jasonw's Avatar
jasonw
Site Moderator
P0070 is the code for "Ambient Air Temperature Sensor Circuit."
Old Sep 3, 2011 | 05:51 PM
master tech
Thank you. I will add it to my list.
