2nd Gen Durango 2004 - 2009
A/C problems....loud screech
Old Oct 30, 2011 | 02:59 AM
emerza's Avatar
emerza
Default A/C problems....loud screech
for some reason when I put on my heat a loud screeching noise will come on....any body got any idea?and also when i put my heat on for the driver and passenger only hot air comes through the passengers side and cold air out of the driver side....any help?
Old Oct 30, 2011 | 09:18 PM
IndyDurango's Avatar
IndyDurango
Heat or defrost?
Sounds like defrost... which is engaging the AC compressor (as it is supposed to.)
Check the belt & idler pulley for replacement first and the compressor secondly.
If not the defrost, no idea. Is the sound localized under the passenger side dash? If so, check the fan.
HTH,
IndyDurango
