2nd Gen Durango 2004 - 2009
Antifreeze smell help. Lot's of new parts
Old Nov 11, 2011 | 12:48 AM
mikehenya's Avatar
mikehenya
Default Antifreeze smell help. Lot's of new parts
Well, I drive a ton, never overheats, temp runs good, just below 1/2 actually. I keep smelling it so I replaced: new radiator, both main hoses, and the auxiliary water pump and I still smell antifreeze. I don't see any leaks on short or long drives. Nothing in the oil that I can see, I just changed it yesterday and it doesn't seem to be losing any water. Bottle is still full, when you take the cap off rad is down to the top of the fins, but I know the bottle fills it back up when it circulates, right? I don't see any on the ground or in the oil, any other thoughts?? I smell it pretty strong every time I stop.
It's a 5.7 that just hit 101k.
Old Nov 20, 2011 | 11:43 PM
n8ech's Avatar
n8ech
Mike:
Sounds like you have done a pretty in depth parts replacement to try to cure this issue. Having gone that far, I would have also done the thermostat since the system was drained.
You may have a loose bolt on the snout that hold it to the side of the water pump. Could also be a seeping/weeping heater hose or seal on the water pump. Coolant leaks have a habit of dripping onto the hot engine evaporating so we don't see them, and just smell them.
Might be productive to pressurize the system with a coolant pressure tester and look for leaks with a cool engine.
You might be able to see the drips then.
Don
Old Nov 21, 2011 | 09:53 AM
patrickjudkins's Avatar
patrickjudkins
id check under your carpet, or turn your ac on full blast and let the car get to operating temp and smell the air coming out of the vents if it smells like coolant more than likely you have a pinhole leak in your heater core, if not check your main water pump weap hole.
Old Nov 21, 2011 | 01:31 PM
2timeram's Avatar
2timeram
Default Antifreeze Smell
I also had a smell and a year later had a nasty squeel. I just(11-18-11) changed the water pump,could not remove the fan from the old pump, so I will put a electric fan on.
Old Nov 25, 2011 | 12:23 PM
mikehenya's Avatar
mikehenya
I suppose the water pump is next, I hate to do it. I should have done it when I had everything else out, I just didn't think. Sigh...
Old Nov 25, 2011 | 10:17 PM
n8ech's Avatar
n8ech
2TR:
You can get the fan off the pump by using a 10 inch crescent wrench opened to the max.
I was able to fashion a tool to hold the pump pulley in place, or you could use one of those belt type wrenches to hold it stationary.
It it on there kind of tight, but a good twist will break it free.
Mike:
If you are doing the pump, do the T stat also.
Don
Old Nov 25, 2011 | 11:42 PM
mikehenya's Avatar
mikehenya
Will definitely do T-Stat also. There goes the holiday time off..ughh. It's always something. Thanks for the advice.
