2nd Gen Durango 2004 - 2009
EGR Valve
Old Nov 11, 2011 | 09:02 AM
jasdas7499's Avatar
jasdas7499
Default EGR Valve
CEL came on in my 2006 Dodge Durango. Checked it with my scanner which came back P0406, EGR valve. Anyone know a rough estimate of replacing this should cost at a dealership? I am not a DIY kind of guy. Thanks!
Old Nov 11, 2011 | 08:57 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I just had mine replaced at the local shop and I think it was $150.00 (Mopar OEM part). Go to the dealer to order the part, but have a local shop install it for less than the dealer,
FF
Old Nov 12, 2011 | 12:18 AM
vintrepid's Avatar
vintrepid
may i know what are the symptoms when the CEL came on & that the EGR valve needs replacing? and typically what mileage will it be? i am thinking of making a long distance drive trip this winter and wouldn't want this to be failing on me if i can help it.
thanks.
Old Nov 12, 2011 | 11:18 AM
1969CoronetR/T
vaffanculo
I replaced the PCV and EGR since they were close to five years old. I had no problems with the the original parts. What codes are you showing (CEL)?
FF
Old Nov 12, 2011 | 12:32 PM
jasdas7499's Avatar
jasdas7499
I don't believe the Durango is showing any symptoms. It's my wife's car so I don't drive it much. The CEL will turn off every now and then and then reappear. It has around 75,000 miles on it. Maybe I should take it for a drive to see if there is any performance issues.
Old Nov 12, 2011 | 12:33 PM
jasdas7499's Avatar
jasdas7499
the code is P0406
Old Nov 12, 2011 | 01:58 PM
vintrepid's Avatar
vintrepid
my D is at 115k kms (77k miles) now. so far so good.....may plan for it to be replaced as a preventive measure. thanks.
