2nd Gen Durango 2004 - 2009
2004 Dodge Durango Rear Door Locked
Old Nov 28, 2011 | 08:51 AM
dnorman's Avatar
dnorman
Default 2000 Dodge Durango Rear Door Locked
I have a 2000 Dodge Durango. The right rear door started to buzz when the doors automatically locked so I took the latch off, cleaned things up and greased everything good. When I put the latch back together I must have not engaged the lock mechanism correctly and when I closed the door it thinks it is locked and so I cannot open the door. I have the inside panel off and cannot see any kind of emergency release. Is there a way to get the door open without physically prying the door open?
Old Nov 28, 2011 | 05:22 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You would want to post this in the first generation Durango section not the second generation Durango section,
FF
Old Nov 29, 2011 | 12:52 AM
IndyDurango's Avatar
IndyDurango
dnorman,
Simply try to open the latch with the exterior handle and then again with the interior handle. I assume you did reconnect the handle and just forgot to reconnect the locking bar. Also, it could simply be the child locks are engaged now.
The buzz you hear is a failing lock mechanism. It will need replaced. Replacement time is under an hour if you follow my entire how-to DIY instructions here:
http://www.durangoclub.com/forum/viewtopic.php?p=102512
My was a 2000 rear door as well so it should be 100% identical. My replacement time was 15 minutes.
Good luck!
IndyDurango
