2nd Gen Durango 2004 - 2009
HID fogs and high beams?
Old Dec 14, 2011 | 06:36 PM
penniman16's Avatar
penniman16
okay thanks guys. do you guys have a diagram of the relay pins because i tried a jumper o nevery single pin on that relay and couldnt get it to work.
Old Dec 15, 2011 | 06:28 PM
geraldd's Avatar
geraldd
Remove the fuse box cover. Pull the fog light relay #62 and the parking light relay #73. Then run about a 8” jumper wire from pin 87 on the fog light relay to the 87 pin on the parking light relay. I used some 18awg speaker wire that I had lying around. I have heard of people soldering the wire but is not necessary. Just wrap the wire around the pin once and put the relays back in place. This will make the fog lights come on when the parking light is turned on. The fog lights will always be on when your lights are on, you lose control of the fog lights. Found a few pictures from the diesel forum gives you an idea.
http://www.cumminsforum.com/forum/3r...h-beams-2.html
Old Dec 15, 2011 | 09:01 PM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by penniman16
No there's a rule with no more than 4 front facing lights. Since I have converted my headlights to hids there is no wattage increase when you put your highs on only the angle in the bulb. So I would technically only have 4 front facing lights and you couldn't technically counts my highs as high and low beams because my wattage never increased only the angle in which the bulb is in the housing
I hope you mean no more than four front facing lights turned on at any time. If someone told you there is a rule against having four facing lights off or on, they had no idea what they're talking about.
Old Dec 16, 2011 | 09:12 PM
geraldd's Avatar
geraldd
Colorado Revised Statutes
42-4-219. Number of lamps permitted.
Whenever a motor vehicle equipped with head lamps as required in this article is also equipped with any auxiliary lamps or a spot lamp or any other lamp on the front thereof projecting a beam of an intensity greater than three hundred candlepower, not more than a total of four of any such lamps on the front of a vehicle shall be lighted at any one time when upon a highway. Any person who violates any provision of this section commits a class B traffic infraction.
