2nd Gen Durango 2004 - 2009
Electrical problems CTM?
Old Feb 5, 2012 | 04:03 AM
D0dge187's Avatar
D0dge187
Default Electrical problems CTM?
ees
Here is my problem along the same lines - DOGE 2004 Durango hemi 5.7
1) Battery connected - clicking relays - flickering dashboard and gauge lights
2) Not able to jumpstart - zero cranking
3) Battery voltage disconnected 12.8v
4) Battery Voltage connected around 6.8 volts and lots of relays clicking
So sure maybe the battery is drained - due to something else sucking the life out of it This does not explain why a jumpstart does not work and based on item 4) something is shorted and pulling down the voltage.
So I need help to quickly diagnose this dude, before I get screwed on Monday taking it into the dealer. Wife blames me, of course, for the problem - jees
Any help needed please respond with any and all ideas - I have read others on this but "replace battery" is not the root cause if the problem again based on 4)
Old Feb 5, 2012 | 01:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
humpheydoo
Remove the right kick panel and check the ground straps on the post. If the ground strap is looseit will cause the relays to make a clicking sounds and the lights to flash.
Old Feb 5, 2012 | 03:56 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
dude, 2004 is 2nd generations duarngo, you will get better responses in that section (im moving this for you)
