2nd Gen Durango 2004 - 2009
05 Durango w/ 5.7 Hemi -- warm engine starting issues
Old Feb 6, 2012 | 09:58 PM
Red Solo's Avatar
Red Solo
Default 05 Durango w/ 5.7 Hemi -- warm engine starting issues
This problem began about 9 months ago and has progressively gotten a bit worse. Initially, the engine started just fine when cold. Once the engine reached normal operating temps and I shut it off for any reason, I sometimes had to lightly press on the gas pedal to get it to start. Now it will start (barely) when the engine is cold w/o pressing on the pedal, but it is a must to give it some throttle when starting the engine warm. It won't even stumble w/o some pedal. There are no engine service lights on and the engine runs great once it's fired up.
Any ideas?
Old Feb 10, 2012 | 05:07 PM
hillbilli's Avatar
hillbilli
My 03 2500 Hemi had a similar issue. It eventually threw a code for a crankcase position sensor, replaced that and it fired up every time hot or cold. Real easy to replace to.
Old Feb 16, 2012 | 04:15 PM
Red Solo's Avatar
Red Solo
But I'm not sure why just a bit of throttle would counteract the crankcase position sensor. I've been wondering if it could be a throttle position sensor, since every once and a while when I'm in town and I back off the throttle, coast, and then get back on the throttle......it will sometimes slightly hesitate.
Old Dec 5, 2012 | 11:44 AM
Butters's Avatar
Butters
Did you ever get this resolved? I'm having the same problem.
