2nd Gen Durango 2004 - 2009
bent bar while jacking, does it need replaced?
Old 02-26-2012 | 01:17 PM
akapone's Avatar
akapone
Default bent bar while jacking, does it need replaced?
So I was jacking up the durango, apparently in the wrong spot. It bent the bar on one side which two bolts connect to in the center, hopefully you can see it in the picture. I am curious if I now need to replace this or will it be ok? Also what is this part of the suspension called?
Attached Thumbnails bent bar while jacking, does it need replaced?-bar1.jpg   bent bar while jacking, does it need replaced?-photo.jpg
Old 02-26-2012 | 07:43 PM
sarguy01's Avatar
sarguy01
Looks like the front crossmember? If it was mine, I'd probably leave it; it doesn't look too bad. I can't tell from the pics, but if you think it moved the lower control arm mounts in I'd get the alignment checked.
Old 02-26-2012 | 08:11 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Could it be the sway bar?
FF
Old 02-26-2012 | 08:22 PM
sarguy01's Avatar
sarguy01
It isn't the sway bar; I crawled under mine. It runs between the two lower control arms and is directly underneath the front axle. Judging from the pics it doesn't look to be something that would worry me. I am going to see if the service manual has a pic of it.
Old 03-01-2012 | 12:50 AM
MileHighRango's Avatar
MileHighRango
its a front support under the front Diff, personally id replace it because its simple a metal bar. Although it is not a main support bar i wouldn't take the risk with family in the car, Dodge put it there for a reason.
Old 03-01-2012 | 07:17 PM
akapone's Avatar
akapone
thanks for the input, ill see if I can find one at the junkyard.
Quick Reply: bent bar while jacking, does it need replaced?
