2nd Gen Durango 2004 - 2009
Driver side seat
Old Mar 5, 2012 | 05:01 PM
Mom2dvas's Avatar
Mom2dvas
Default Driver side seat
So I just got my 2005 durango limited and I love it however I raised the seat to high and there doesn't seem to be a way to lower it? Can anyone help me?
Old Mar 5, 2012 | 11:42 PM
sarguy01's Avatar
sarguy01
Push the button down??? That is what I do.
Old Mar 6, 2012 | 10:14 AM
Mom2dvas's Avatar
Mom2dvas
Thats obvious however when I tried it doesn't go down not that it doesn't work but it's not an option
Old Mar 6, 2012 | 12:32 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Does your seat control look like a drawing of a seat. A rectangular button on the bottom and a rectangular button upright for the back of the seat like this _ l
FF
Old Mar 7, 2012 | 09:02 AM
Mom2dvas's Avatar
Mom2dvas
Yes it does the bottom goes up when pressed but not down like it isn't an option
Old Mar 7, 2012 | 07:18 PM
1969CoronetR/T
vaffanculo
Mine does not really go up. The center section tilts up or down when you press the tip of the longitudinal bar button, but the seat frame does not move.
FF
Old Mar 7, 2012 | 08:39 PM
Durangonut's Avatar
Durangonut
Default Jumper wire
When I had a problem with the seat in my intrepid I used a Jumper wire to adjust my seat. Find the main power wire and insert one end of the jumper wire into the plug where the wires go in than poke the other end into the other wires to move your seat. This will only work if the switch is broke and not the motor. It sounds like the motor works since you were able to raise your seat. Hope this helps.
Old Mar 8, 2012 | 03:39 PM
Mom2dvas's Avatar
Mom2dvas
I can't figure it out I mean it want up but not down! Very frustrating, I even downloaded the owners manual on my I book needless to say I got the auto lock when in gear to be enabled again! Lol any other ideas please let me know! Thanks to you all for your suggestions!!!!!
Old Mar 9, 2012 | 10:09 PM
n8ech's Avatar
n8ech
Mom2:
Try running it back and forth a number of times, and then run the front up and down. Then, run the back up and down.
Could be that it is a bit frozen up due to non use, or you could have a motor or switch issue.
Don
