2nd Gen Durango 2004 - 2009
Wheels sizing
Old Mar 5, 2012 | 09:30 PM
MichDude's Avatar
MichDude
Default Wheels sizing
Does anyone know if Dodge Ram wheels will fit my 04 durango? I also have a chance to get Jeep grand Cherokee wheels as well, just not sure if bolt pattern will work. I believe the jeep liberty wheels probably not work? right? Just trying to get a good deal on wheels as my stock ones have alot of corrosion. My co-worker suggested powder coating my durangos wheels, I am all for that if its affordable..anyone know how much it would cost on average?
Thanks,
Old Mar 6, 2012 | 12:24 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The 2004 Durango 4x4 and the 2004 Dodge Ram 1500 4x4 have the same bolt pattern at 5-139. The 2004 Jeep Liberty 4x4 has a different bolt pattern at 5-114. Youcan go to www.tirerack.com and they have a feature where you can look at wheels and their sizes.
FF
Old Mar 6, 2012 | 06:15 PM
MichDude's Avatar
MichDude
Thanks for the link Fascistfaction, I will look there.
Old Mar 6, 2012 | 08:27 PM
1969CoronetR/T
vaffanculo
I do not know if all Rams and all Durangos have the 5-139 bolt pattern, but you can measure the the wheel lug nut spacing and count the lug nut holes. I think you measure from the second lug nut hole across to the fourth lug nut hole with the first lug nut hole in the twelve position. It should be 139 mm.
FF
Old Mar 12, 2012 | 09:09 PM
pershingd's Avatar
pershingd
All 2nd gen Durangos will accept the 2003 and up Dodge Ram wheels. They used the same brakes and some front end pieces from the truck line.
I've got wheels from an '07 Ram on mine at the moment.
