2nd Gen Durango 2004 - 2009
Interior lights doesn't turn on
Old Aug 8, 2012 | 12:59 PM
J-H's Avatar
J-H
Default Interior lights doesn't turn on
Hi
I have a 2004 Durango with some problems, one of them is that the interior lights doesn't turn on, at all. Do anyone have any idea what might be wrong?
Thanks
Old Aug 8, 2012 | 01:45 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Safercar.gov has MANY recalls for the 2004:
Make: DODGE Model: DURANGO
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 12, 2003
NHTSA CAMPAIGN ID Number: 03V528000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH
Potential Number of Units Affected: 27,586
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, AN INSTRUMENT CLUSTER CIRCUIT BOARD CAPACITOR MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY RESULT IN AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL REMOVE THE CAPACITOR FROM THE CIRCUIT BOARD. OWNER NOTIFICATION BEGAN ON DECEMBER 17, 2003. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-992-1997.
Notes:
DAIMLERCHRYSLER RECALL NO. C43. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: JAN 13, 2004
NHTSA CAMPAIGN ID Number: 04V020000 NHTSA Action Number: N/A
Component: VEHICLE SPEED CONTROL:CABLES
Potential Number of Units Affected: 21,053
Summary:
ON CERTAIN SPORT UTILITY VEHICLES EQUIPPED WITH 3.7L AND 4.7L ENGINES, THE THROTTLE CONTROL CABLE MAY INGEST WATER AND FREEZE DURING EXTENDED COLD TEMPERATURE.
Consequence:
THIS COULD CAUSE THE THROTTLE TO STICK IN THE OPEN POSITION AND RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE THROTTLE CONTROL CABLE. OWNER NOTIFICATION BEGAN ON JANUARY 19, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D02. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 07, 2004
NHTSA CAMPAIGN ID Number: 04V578000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Potential Number of Units Affected: 71,763
Summary:
ON CERTAIN SPORT UTILITY VEHICLES BUILT WITH A 5.7L, 4.7L, OR 3.7L ENGINE, THE POSITIVE BATTERY CABLE MAY CONTACT THE FRONT SUSPENSION UPPER CONTROL ARM MOUNTING BRACKET.
Consequence:
THIS CONTACT COULD ABRADE THE CABLE AND CAUSE A SHORT CIRCUIT, WHICH MAY RESULT IN AN UNDERHOOD FIRE.
Remedy:
DEALERS WILL INSPECT THE BATTERY CABLE AND, IF NECESSARY, REPOSITION IT AWAY FROM THE CONTROL ARM MOUNTING BRACKET. THE RECALL BEGAN DECEMBER 14, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D40. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: MAR 06, 2007
NHTSA CAMPAIGN ID Number: 07V092000 NHTSA Action Number: EA06015
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
ON SOME SPORT UTILITY VEHICLES, UNDER CERTAIN OPERATING CONDITIONS, AN INTEGRATED CIRCUIT IN THE INSTRUMENT CLUSTER THAT CONTROLS INTERIOR LIGHTING MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL INSPECT THE CLUSTER FOR DAMAGE AND REPLACE IT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-140.
Notes:
DAIMLERCHRYSLER RECALL NO. G07. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2004
Manufacturer: SABERSPORT Mfr's Report Date: MAR 28, 2009
NHTSA CAMPAIGN ID Number: 09E012000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Old Aug 8, 2012 | 03:26 PM
J-H's Avatar
J-H
Can you see if any of this has already been replace? I´m guessing that the cluster is causing these faults that I´m having with my car.
Old Aug 9, 2012 | 08:32 AM
1969CoronetR/T
vaffanculo
Call any dealer and they will need your VIN to determine if any recalls pertaining to your vehicle have been completed.
FF
Old Aug 9, 2012 | 09:56 AM
DodgeCares's Avatar
DodgeCares
J-H,
If you PM me your VIN with a note requesting recall info I will let you know about any recalls on your vehicle.
Old Aug 9, 2012 | 03:21 PM
J-H's Avatar
J-H
DodgeCares,
Thank you for your help!
Old Aug 9, 2012 | 03:53 PM
DodgeCares's Avatar
DodgeCares
DodgeCares,
YW. PM sent.
Old Aug 15, 2012 | 12:33 AM
dodgemramem's Avatar
dodgemramem
Hi
Thanks
I had the same problem. Took it into a local Dodge dealership and they told me it was a recall fix.
Just a warning. They will not let you take your car back until they fix the problem. Fortunately they were able to fix mine in a couple of days.
Old Aug 20, 2012 | 03:05 PM
J-H's Avatar
J-H
It´s was a recall fix on mine aswell.
Old Aug 23, 2012 | 04:51 AM
Challenger383's Avatar
Challenger383
I guess you must have tried this, but just check the dash dimmer switch isn't in the off position. Just a thought.
