2nd Gen Durango 2004 - 2009
Electrical gong crazy
Old Sep 26, 2012 | 11:49 PM
JHenfling's Avatar
JHenfling
New Member
Default Electrical gong crazy
It happens when I first get in my Durango and start it up. The radio goes on and off the service 4wd light along with the battery light, the pegs on the speedometer and rpm gauge drop and then go back up. The DVD player says VES error but when I finally get the DVD player to,work all of the other things work perfectly. What could this be I need all the help I can get.
Old Sep 26, 2012 | 11:54 PM
MileHighRango's Avatar
MileHighRango
saw another D with this problem and i believe it turned out to be a "blown" fuse, the fuse was intermittent for some reason. Not sure what fuse it was though, good luck!
Old Sep 27, 2012 | 07:48 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
What year is your Durango?
FF
Old Sep 27, 2012 | 10:39 AM
JHenfling's Avatar
JHenfling
New Member
It's an 05 limited with the 5.7 Hemi
Old Sep 27, 2012 | 11:20 AM
1969CoronetR/T
vaffanculo
They are a few recalls for your Durango and one pertains to the instrument cluster and in now infamous gas purging tank. Not sure if this will cure your present problem, but you can call a dealer with your VIN to see if any recalls pertain to your vehicle:
Make: DODGE Model: DURANGO
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: FEB 01, 2005
NHTSA CAMPAIGN ID Number: 05V034000 NHTSA Action Number: N/A
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Potential Number of Units Affected: 26,000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE FUEL TANK FILLER TUBE INLET CHECK VALVE MAY NOT FULLY CLOSE AT THE END OF REFUELING. THIS COULD ALLOW SOME FUEL TO ESCAPE FROM THE VEHICLE FILLER NECK.
Consequence:
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE CAN RESULT IN A FIRE.
Remedy:
DEALERS WILL INSPECT THE INLET CHECK VALVES AND REPLACE THE FUEL TANK ASSEMBLY FREE OF CHARGE. THE RECALL BEGAN ON APRIL 4, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. E01. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Check to Request Research. Submit below.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: OCT 04, 2005
NHTSA CAMPAIGN ID Number: 05V460000 NHTSA Action Number: N/A
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
ON CERTAIN PICKUP TRUCKS, SPORT UTILITY AND PASSENGER VEHICLES EQUIPPED WITH 42RLE AUTOMATIC TRANSMISSIONS, THE CUP PLUG THAT RETAINS THE PARK PAWL ANCHOR SHAFT MAY BE IMPROPERLY INSTALLED. IF THE SHAFT MOVES OUT OF POSITION, THE VEHICLE MAY NOT BE ABLE TO ACHIEVE 'PARK' POSITION.
Consequence:
IF THIS OCCURS AND THE PARKING BRAKE IS NOT APPLIED, THE VEHICLE MAY ROLL AWAY AND CAUSE A CRASH WITHOUT WARNING.
Remedy:
DEALERS WILL INSPECT THE TRANSMISSIONS AND INSTALL A BRACKET TO ENSURE THE PARK PAWL ANCHOR SHAFT IS RETAINED IN THE PROPER POSITION. THE RECALL BEGAN ON NOVEMBER 28, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. E14. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236; (TTY:1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: MAR 07, 2006
NHTSA CAMPAIGN ID Number: 06V067000 NHTSA Action Number: N/A
Component: VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Summary:
ON CERTAIN VANS AND SPORT UTILITY VEHICLES, THE FRONT WINDSHIELD WIPER MOTOR ARMATURE SHAFT MAY BREAK.
Consequence:
DURING CERTAIN OPERATING CONDITIONS, LOSS OF FRONT WINDSHIELD WIPING CAPABILITY COULD OCCUR, AND THE DRIVER'S VISION COULD BE OBSCURED WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE WINDSHIELD WIPER MOTOR FREE OF CHARGE. THE RECALL BEGAN ON JUNE 19, 2006, TO DODGE DURANGO OWNERS. MINIVAN OWNERS WILL BE NOTIFIED DURING JULY 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. F10. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: MAR 06, 2007
NHTSA CAMPAIGN ID Number: 07V092000 NHTSA Action Number: EA06015
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
ON SOME SPORT UTILITY VEHICLES, UNDER CERTAIN OPERATING CONDITIONS, AN INTEGRATED CIRCUIT IN THE INSTRUMENT CLUSTER THAT CONTROLS INTERIOR LIGHTING MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL INSPECT THE CLUSTER FOR DAMAGE AND REPLACE IT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-140.
Notes:
DAIMLERCHRYSLER RECALL NO. G07. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: SABERSPORT Mfr's Report Date: MAR 28, 2009
NHTSA CAMPAIGN ID Number: 09E012000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Model Year: 2005
Manufacturer: CHRYSLER LLC Mfr's Report Date: JAN 06, 2009
NHTSA CAMPAIGN ID Number: 09V003000 NHTSA Action Number: RQ08005
Potential Number of Units Affected: 18,951
Summary:
CHRYSLER IS RECALLING 18,951 MY 2005 DODGE DURANGO VEHICLES. THE FUEL TANK FILLER TUBE INLET CHECK VALVE MAY NOT FULLY CLOSE AT THE END OF REFUELING. THIS COULD ALLOW SOME FUEL TO ESCAPE FROM THE VEHICLE THROUGH THE FILLER NECK AT THE END OF REFUELING.
Consequence:
Remedy:
DEALERS WILL INSPECT THE FUEL TANK INLET CHECK VALVE. VEHICLES FOUND TO HAVE A SUSPECT INLET CHECK VALVE WILL HAVE THE FUEL TANK ASSEMBLY REPLACED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Notes:
CHRYSLER RECALL NO. H45. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Old Sep 27, 2012 | 12:31 PM
DodgeCares's Avatar
DodgeCares
Jhen,
There was a recall on the instrument cluster on some of these vehicles. If you want to PM me your Vin I will check for you to see if you have any open recalls and also look for any other service bulletins that may apply to the symptoms you are having with the vehicle.
Old Sep 27, 2012 | 12:48 PM
JHenfling's Avatar
JHenfling
New Member
Pm sent
Old Sep 28, 2012 | 06:16 PM
Mick Maag's Avatar
Mick Maag
my electrical is going haywire as well. bell dings when i take key out and turn off lights and shut door.. when i open door.. still dings and wont lock.. if i wait about 1/2 hr .. i open door and dings once then no more.. 4 wd is stuck, when i shut engine off.. still runs for about 6 sec. pisssing me off.. lol
