2nd Gen Durango 2004 - 2009
Headlight Removal/Installation on 2008 Durango
Old Oct 18, 2012 | 11:25 AM
pcstrick's Avatar
pcstrick
Default Headlight Removal/Installation on 2008 Durango
How do I remove the headlight assembly on a 2008 Dodge Durango?
Old Oct 18, 2012 | 01:01 PM
DodgeCares's Avatar
DodgeCares
1.Disconnect and isolate the battery negative cable.
2.Carefully pry up the lower edge of the access panel from the access opening in the front of the front fender liner.
3.Lift the lower edge of the access panel upward far enough to access the nut that secures the back of the front lamp unit to the reinforcement in the front fender.
4.Reach through the fender liner access opening to remove the nut that secures the stud on the back of the front lamp unit to the reinforcement of the fender.
5.Remove the two screws that secure the top of the lamp to the upper inner reinforcement of the fender.
6.Grasp the lamp firmly and pull straight forward to disengage the ball stud on the back of the lamp from the plastic grommet in the fender reinforcement.
7. Pull the lamp away from the fender far enough to access and disconnect three wire harness connections from the back of the lamp: a. front park/turn signal bulb socket
b. headlamp bulb
c. side marker bulb socket
8. Remove the front lamp unit from the fender.
