2nd Gen Durango 2004 - 2009
2005 Dodge Durango ABS and Traction Control Light On AGAIN!
Old Nov 1, 2012 | 06:33 PM
Bosshog5's Avatar
Bosshog5
Default 2005 Dodge Durango ABS and Traction Control Light On AGAIN!
First of all my Durango is a 2005 SLT rear wheel drive. Just earlier today, my ABS and Traction Control light came on. This is the fourth time my dashboard lights have came on and stayed on. The previous times these two lights came, the Brake light came on. The last three times the cruise control stopped working but I haven't tried it out this time yet. The new thing this time is when you have the heat or defrost on or I guess the blower and you turn the car off, taking the keys all the way out, they continue to run. You have to manually turn the **** to shut them off when they should shut off when you turn the car off. When I have had it repaired the people said one time that it was a wheel sensor and two other times the ABS module went out (that's what they said was wrong). Also, the last time I had it repaired the guy said that water was getting into a place causing something to go out. The thing is it hasn't rained for maybe 2 or 3 weeks here and it wen't out today. Please help me. Thanks
Old Nov 3, 2012 | 02:50 PM
Bosshog5's Avatar
Bosshog5
My wife wen't to start it today and the battery is dead. This actually happened once before when the lights came on so something is draining the battery. The durango is also a 5.7L HEMI. Please help.
Old Nov 3, 2012 | 06:48 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Call your dealer to see if any of these recall pertain to your VIN. One is for the instrument panel:
FF
Make: DODGE Model: DURANGO
Model Year: 2005
Manufacturer: SABERSPORT Report Receipt Date: APR 07, 2009
NHTSA CAMPAIGN ID Number: 09E012000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Check to Request Research. Submit below.
Model Year: 2005
Manufacturer: CHRYSLER LLC Report Receipt Date: JAN 08, 2009
NHTSA CAMPAIGN ID Number: 09V003000 NHTSA Action Number: RQ08005
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Potential Number of Units Affected: 18,951
Summary:
CHRYSLER IS RECALLING 18,951 MY 2005 DODGE DURANGO VEHICLES. THE FUEL TANK FILLER TUBE INLET CHECK VALVE MAY NOT FULLY CLOSE AT THE END OF REFUELING. THIS COULD ALLOW SOME FUEL TO ESCAPE FROM THE VEHICLE THROUGH THE FILLER NECK AT THE END OF REFUELING.
Consequence:
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE CAN RESULT IN A FIRE.
Remedy:
DEALERS WILL INSPECT THE FUEL TANK INLET CHECK VALVE. VEHICLES FOUND TO HAVE A SUSPECT INLET CHECK VALVE WILL HAVE THE FUEL TANK ASSEMBLY REPLACED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Notes:
CHRYSLER RECALL NO. H45. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Report Receipt Date: MAR 09, 2007
NHTSA CAMPAIGN ID Number: 07V092000 NHTSA Action Number: EA06015
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
ON SOME SPORT UTILITY VEHICLES, UNDER CERTAIN OPERATING CONDITIONS, AN INTEGRATED CIRCUIT IN THE INSTRUMENT CLUSTER THAT CONTROLS INTERIOR LIGHTING MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL INSPECT THE CLUSTER FOR DAMAGE AND REPLACE IT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-140.
Notes:
DAIMLERCHRYSLER RECALL NO. G07. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Report Receipt Date: MAR 08, 2006
NHTSA CAMPAIGN ID Number: 06V067000 NHTSA Action Number: N/A
Component: VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Summary:
ON CERTAIN VANS AND SPORT UTILITY VEHICLES, THE FRONT WINDSHIELD WIPER MOTOR ARMATURE SHAFT MAY BREAK.
Consequence:
DURING CERTAIN OPERATING CONDITIONS, LOSS OF FRONT WINDSHIELD WIPING CAPABILITY COULD OCCUR, AND THE DRIVER'S VISION COULD BE OBSCURED WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE WINDSHIELD WIPER MOTOR FREE OF CHARGE. THE RECALL BEGAN ON JUNE 19, 2006, TO DODGE DURANGO OWNERS. MINIVAN OWNERS WILL BE NOTIFIED DURING JULY 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. F10. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Report Receipt Date: OCT 06, 2005
NHTSA CAMPAIGN ID Number: 05V460000 NHTSA Action Number: N/A
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
ON CERTAIN PICKUP TRUCKS, SPORT UTILITY AND PASSENGER VEHICLES EQUIPPED WITH 42RLE AUTOMATIC TRANSMISSIONS, THE CUP PLUG THAT RETAINS THE PARK PAWL ANCHOR SHAFT MAY BE IMPROPERLY INSTALLED. IF THE SHAFT MOVES OUT OF POSITION, THE VEHICLE MAY NOT BE ABLE TO ACHIEVE 'PARK' POSITION.
Consequence:
IF THIS OCCURS AND THE PARKING BRAKE IS NOT APPLIED, THE VEHICLE MAY ROLL AWAY AND CAUSE A CRASH WITHOUT WARNING.
Remedy:
DEALERS WILL INSPECT THE TRANSMISSIONS AND INSTALL A BRACKET TO ENSURE THE PARK PAWL ANCHOR SHAFT IS RETAINED IN THE PROPER POSITION. THE RECALL BEGAN ON NOVEMBER 28, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. E14. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236; (TTY:1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2005
Manufacturer: DAIMLERCHRYSLER CORPORATION Report Receipt Date: FEB 03, 2005
NHTSA CAMPAIGN ID Number: 05V034000 NHTSA Action Number: N/A
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Potential Number of Units Affected: 26,000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE FUEL TANK FILLER TUBE INLET CHECK VALVE MAY NOT FULLY CLOSE AT THE END OF REFUELING. THIS COULD ALLOW SOME FUEL TO ESCAPE FROM THE VEHICLE FILLER NECK.
Consequence:
Remedy:
DEALERS WILL INSPECT THE INLET CHECK VALVES AND REPLACE THE FUEL TANK ASSEMBLY FREE OF CHARGE. THE RECALL BEGAN ON APRIL 4, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. E01. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
