2nd Gen Durango 2004 - 2009
HELP 04 Dodge Durango 4.7 Timing/Head Gasket
Old Nov 7, 2012 | 07:10 PM
lvfd404's Avatar
lvfd404
Default HELP 04 Dodge Durango 4.7 Timing/Head Gasket
I am looking for some clarification on timing. I have the motor stripped down and the heads off and at the machine shop. I had someone from a local garage give me a hand to make sure nothing was messed up when I got to the part about timing. Well I dont believe he was knowledgable as he claimed. I set the crank slot to TDC. The two cam gears were lined up with the v8 mark at the 12oclock position. When he busted the bolt loose for the crank/harmonic balancer, the timing mark is now slightly off. When he busted the bolts loose for the gears at the cam, the cam rotated a little as well. I had not noticed this. Prior to taking the cam gears off, I did zip tie the timing chain to the guides so they didnt move or drop. But that was prior to me realizing the crank moved a little from TDC. Now I am sort of lost what I need to do to ensure proper timing. Do i put the harmonic balancer back on and move back to tdc then pull back off? Since I have the two cam chains zip tied down do i need to do this after i get the heads back on and gears back on the cam? Then just put the cam gears at V8 12oclock? I apologize for this being all over the place but I dont want to have the timing messed up and bend a valve or worse. I appreciate your help in advance as you all in these forums really help everyday people out.
Old Nov 11, 2012 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Here is some information, if you need more. Let me know.
INSTALLATION
1 - VISE
2 - TENSIONER BODY
3 - INSERT LOCK PIN
4 - RATCHET
5 - PISTON
Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin.
Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 N·m (250 in. lbs.).
CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
Install right side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
NOTE: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
Install the left side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
Install left side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
Install the right side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
1 - LOCK ARM
2 - RIGHT CAMSHAFT CHAIN
3 - SECONDARY CHAINS RETAINING PINS (4)
4 - IDLER SPROCKET
5 - LEFT CAMSHAFT CHAIN
6 - SPECIAL TOOL 8515
1 - SPECIAL TOOL 8429
2 - PRIMARY CHAIN IDLER SPROCKET
3 - CRANKSHAFT SPROCKET
Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation .
Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket .
Lubricate idler shaft and bushings with clean engine oil.
Install all chains, crankshaft sprocket, and idler sprocket as an assembly. After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation.
NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
Align left camshaft sprocket “L” dot to plated link on chain.
Align right camshaft sprocket “R” dot to plated link on chain.
CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
Verify that all plated links are aligned with the marks on all sprockets and the “V8” marks on camshaft sprockets are at the 12 o'clock position (Timing Chain System).
CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
Install both secondary chain tensioners. Tighten bolts to 28 N·m (250 in. lbs.).
NOTE: Left and right secondary chain tensioners are not common.
Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 N·m (25 ft. lbs.).
Remove all locking pins from tensioners.
CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
1 - TORQUE WRENCH
2 - CAMSHAFT SPROCKET
3 - LEFT CYLINDER HEAD
4 - SPECIAL TOOL 6958 SPANNER WITH ADAPTER PINS 8346
1 - TORQUE WRENCH
2 - SPECIAL TOOL 6958 WITH ADAPTER PINS 8346
3 - LEFT CAMSHAFT SPROCKET
4 - RIGHT CAMSHAFT SPROCKET
Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left and right, camshaft sprocket bolts to 122 N·m (90 ft. lbs.).
Rotate engine two full revolutions. Verify timing marks are at the follow locations:
primary chain idler sprocket dot is at 12 o'clock
primary chain crankshaft sprocket dot is at 6 o'clock
secondary chain camshaft sprockets “V8” marks are at 12 o'clock
Lubricate all three chains with engine oil.
1 - IDLER SPROCKET ASSEMBLY
2 - DIAL INDICATOR
After installing all chains, it is recommended that the idler gear (1) end play be checked. The end play must be within 0.10–0.25 mm (0.004–0.010 in.). If not within specification, the idler gear must be replaced.
Install timing chain cover and crankshaft damper.
Install cylinder head covers.
NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 81 N·m (60 ft. lbs.)
Install the oil fill housing.
Install access plug in left cylinder head.
Install power steering pump.
Install radiator fan shroud.
Fill cooling system.
Connect negative cable to battery.
Old Nov 13, 2012 | 08:17 PM
lvfd404's Avatar
lvfd404
Well my problem just goes from bad to worse. Local shop said head gaskets bad. Cause for my overheating. I didnt like nor able to afford the 2500$ repair bill so I went ahead and used a block test kit to check for exhaust gas after the shop said needed the head gasket. It turned yellow and confirmed it. Tore down, took heads to reputable shop and they machined them .003. Put new fel-pro gaskets on, torqued to proper setting and put everything back together. Re-tested with block test kit for s and giggles to verify the job well done and it yet again turns yellow. I am not sure what the deal is or anything. Any help or insight would be so much appreciated.
Old Nov 13, 2012 | 08:46 PM
steak59's Avatar
steak59
are you overheating?
