2nd Gen Durango 2004 - 2009
Fuel Ratio rich and High air flow, constant limp mode when braking.
Old Feb 15, 2013 | 11:06 PM
DomTheDurango's Avatar
DomTheDurango
Default Fuel Ratio rich and High air flow, constant limp mode when braking.
Dodge Durango 2004, 5.7L Hemi v8 174k Miles
Hi,
Its been about 2 year since it all this started and i just can't figure it out.
I am receiving the codes:
P2172 Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
P0175 2/1 Fuel Sys Rich
When I am coasting or braking (Foot isn't on the gas pedal) my car will go into a limp mode and the ETC light flashes until I restart the car. When idle the cars RPM will fluxuate from around 600 to 1300
I changed the throttle body out recently and replaced the spark plugs a while back when all this first start, but now its getting really bad. I may try and replace spark plugs again.
Thanks
Old Feb 16, 2013 | 07:18 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I believe Champion copper are the OEM spark plugs. Your PCM may be the cause.
FF
Old Feb 16, 2013 | 01:56 PM
DomTheDurango
Thanks for the reply Fascistfaction, what exactly are you saying here? that the spark plugs are causing the problem and I should reset the PCM?
Old Feb 16, 2013 | 07:16 PM
1969CoronetR/T
vaffanculo
I would look at the PCM.
FF
