2nd Gen Durango 2004 - 2009
'04 Durango Won't Start - Transmission Grinding
Old Mar 18, 2013 | 02:23 PM
DevilDogge's Avatar
DevilDogge
Default '04 Durango Won't Start - Transmission Grinding
This thing is my wife's daily driver. Saturday I started it up to move our 6k# boat around so I could wax it. I left it hooked up (wheels of the boat chalked) through to today (Monday), and when my wife tried to start it, it just made a loud grinding noise for a split second, then would stop. It would grind every time you turn the key, so I figured it was a bad starter.
Once I got it into the garage, jacked it up, and had my wife crank it while I was under looking at the starter, I realized the sound seemed to be coming from the front left of the transmission, almost sounded like directly in the pan. This has got me concerned now. I made a video of the sound in hopes of some suggestions.
Old Mar 18, 2013 | 07:50 PM
DevilDogge's Avatar
DevilDogge
Just checked the CELs.
P0700 : Transmission control system
P0562 : Transmission system low voltage
P0571 : Brake switch A circuit.
Old Mar 18, 2013 | 08:13 PM
DevilDogge's Avatar
DevilDogge
The battery if fairly new, and everything seems to have plenty of power (windows, lights, power seat, etc...). It doesn't seem like a dead battery when you try to crank it and then everything shuts off and you get the relay click.
I checked, and cleaned the battery posts and put the charger on the battery just in case. Hopefully it's just a battery problem.
Old Mar 31, 2013 | 09:32 AM
DevilDogge's Avatar
DevilDogge
Snapped piston rod. Put hole through block. Hydrolocked due to heavy rain, leaky intake manifold gasket, and engine stopping just before the #8 cylinder compression stroke.
Old Apr 1, 2013 | 07:11 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
That sucks. An engine with a view.
FF
