2nd Gen Durango 2004 - 2009
Tow/Haul buttom behavior
Old Sep 17, 2005 | 06:03 PM
Erwinf's Avatar
Erwinf
Default Tow/Haul buttom behavior
Sorry guys that I insist on this but I just want to make sure the this little buttom is working properly.
Q: Am I right if I compare the functionality of this buttom with the O/D buttom (OverDrive) found on many other automatic cars. I read on the manual that once you depress the Tow/Haul the transmission is supposed to avoid shifting to the 5th gear. Is that correct?
Thanks,
Old Sep 17, 2005 | 07:43 PM
jasonwyo's Avatar
jasonwyo
Default RE: Tow/Haul buttom behavior
yep, and it will also spread the other four gears over a wider rpm range for more power when towing or climbing grades.
