2nd Gen Durango 2004 - 2009
Auxiliary pump
Old May 29, 2013 | 08:32 PM
pgtek's Avatar
pgtek
Default Auxiliary pump
Hi Guys
My auxiliary water pump is leaking.
Can i bypass it without any problem?
I think it for the rear heat only
Thanks
Old Jun 9, 2013 | 05:23 PM
n8ech's Avatar
n8ech
PG:
I have read where others have done this with no ill effect. IIRC, the pump only runs below 17mph or so when rear heat is called for.
Above that, most likely the engine is making enough heat and running fast enough to do the job.
Don
