2nd Gen Durango 2004 - 2009
Oil Light Came On
Old Aug 24, 2013 | 09:11 PM
qtband's Avatar
qtband
Default Oil Light Came On
I made a hard right hand turn and when I came to a stop the oil light (and annoying beep) came on. I immediately pulled over and checked the oil. It was a little low so I added oil. The light and beep still come on. The engine sounds fine. Is there a wire or something that might have come loose or something? Any ideas?
2006 Durango 66xxx miles
Old Aug 25, 2013 | 09:33 PM
MIKEon22s's Avatar
MIKEon22s
Yes the wire from the oil pressure sender or pressure sending unit may be bad. May want to double check oil level, hard stop and hard corner low/no oil pressure are a sign of low oil and its being forced away from the pickup so its sucking air.
Old Aug 25, 2013 | 10:37 PM
qtband's Avatar
qtband
I did check the oil and it was fine. Do the sending units go bad?
Old Aug 25, 2013 | 10:46 PM
MIKEon22s's Avatar
MIKEon22s
they can
