Help here please
Hi guys, im new here. I have a 2005 durango limited w/o navigation but i want to change my radio to a 2dim. I want to know is the bezel of the navigation fits mine?
Thanks in advance for the help.
go to a dodge dealer the parts guys can look that up in there books. but you'll need a really good parts guy. one time i looked up parts for a 82 ram cab light switch. turns out they used two different types of switch, for that year. course i only needed one type of switch
I have looked into this and it's not that straight forward as you might think, It's possible, depends on wether you have air con or climate control for a start, as the radio/cd. heating control bezels are different. If you have climate control, the process is more straight forward.
Ask the same question on the Audio section on this forum, and look for my posts on the same subject aprox Jun or July last year.... hope this helps
Are you putting a OEM radio sat/nav unit,or after market one in. I have looked into this a bit and it would seem, that cars the same as ours have radio/cd and air con, the OEM radio sat/nav, seems to come with climate control, these two heating controls are different sizes, if you look at the partition bar on your wood effect bezel and the brushed ali bezel, they are different thicknesses. you would also need a Pac ( cant remember the part number) lead so your Can bus system still works. I am by no means upto speed on this, you need to ask the question in the Audio section, there are some well knowledgeable people there to offer advise
