2nd Gen Durango 2004 - 2009
Seats
Old Jan 1, 2014 | 11:14 AM
MichDude's Avatar
MichDude
Default Seats
Hello, I have an opportunity to buy a pair of heated seats from an 05 durango to go into my non heated seats 04 durango. My question then is, will it work, do I need something else? It will come with the harness but not sure if it will work as my 04 seats are non heated. Any thoughts or suggestions? These will hopefully help my aching back on long trips!
Happy Holidays!
thx
Old Jan 2, 2014 | 07:20 PM
azcromntic's Avatar
azcromntic
I have an '05 with heated seats. In mine there are two switches to turn the seats on and off. Did the harness come with the two switches that are mounted at the bottom of the center of the dash board (beneath the temperature controls)?
If not then you'd need those. And probably a wiring diagram for an '05 to figure out where the harness goes to. If your '04 wiring has a place for the wiring harness to plug into then I'd say your good to get started. If not then you'll have to figure out where to drop off a circuit and do custom wiring.
