2nd Gen Durango 2004 - 2009
Doesn't idle down when coasting
Old Jan 21, 2014 | 12:40 AM
azcromntic's Avatar
azcromntic
Default Doesn't idle down when coasting
So part of the reason I can get a whopping 15 mpg city with my Durango (sometimes) is that I have a few hills that I can coast down for nearly 5 miles. I've noticed though that the rpm's when coasting are at 1500 instead of the normal idle rpm. What gives?
I was thinking that maybe there is a vacuum leak somewhere but I don't know that much about this transmission so I thought I would post here to see if anyone might know.
I have the electronically controlled transmission.
Old Jan 21, 2014 | 07:31 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Are you in drive or neutral while coasting down the hills?
FF
Old Jan 21, 2014 | 06:52 PM
azcromntic's Avatar
azcromntic
Forgot to mention, Neutral.
Old Jan 21, 2014 | 07:22 PM
outbackgeorgia's Avatar
outbackgeorgia
I believe that is correct behavior, as this is what mine does, seems like a grade retard action by the transmission. On really long downhills, it keeps the speed down without using brakes.
Dave
Old Jan 24, 2014 | 11:22 AM
azcromntic's Avatar
azcromntic
I could accept that if it weren't for the fact that it is in neutral. Maybe the firmware for the transmission isn't that robust. Is there a way to "tune" the transmission?
