2nd Gen Durango 2004 - 2009
Overheating/antifreeze leak
Old Jul 22, 2014 | 12:56 PM
thehathaways's Avatar
thehathaways
Default Overheating/antifreeze leak
I have a 2007 Durango SLT with the 4.7, I was told my tow capacity is 6500lbs, my camper is 4500 dry.
After towing for 4 hours or so, I develop a overheating issue. I was using A/C.
If I switch the heat on some it does help.
I also believe that I have a slow leak somewhere, I can smell antifreeze when I start the vehicle and after a while, I do need to put in antifreeze.
I did change the thermostat about 2 years ago.
When I open the radiator cover(cold), there is a gurgle and antifreeze seems to empty into the jug on the right, sometimes spilling out.
Is this normal?
Thank you,
Steve
Old Jul 22, 2014 | 05:58 PM
theraymondguy's Avatar
theraymondguy
You can sort out your towing capacity with the owners manual.
http://www.dodge.com/en/owners/manuals/
You need to do a cooling system pressure test to locate the leak. You can buy an inexpensive test kit for about $100 - what your local garage will charge to perform the test.
If you'd like to throw a $20 dart at it, try replacing the radiator cap. After 7 years it'll be due for replacement regardless.
Old Nov 17, 2014 | 08:25 PM
VItimmy's Avatar
VItimmy
You might have an airlock. I've been having overheating issues for a while and after replacing water pump thermostat rad cap my buddy looked it over and said there's probably an airlock. It was not something I even thought of.
