2nd Gen Durango 2004 - 2009
2000 dodge durango r/t
Old Jul 27, 2014 | 03:15 PM
walter.valdez2's Avatar
walter.valdez2
Default 2000 dodge durango r/t
I wanted to see if anyone can hel p with my durango. So in the mornings when I go to start it it stalls then I have to keep the idle up by pushing on the gas the I drives and starts normal the whole day. I have changed out the fan clutch, iac sensor, tps, air filter, fuel pump and fuel filter is on the pump so filter too. What could it be please HELP ME !!!!!!
Old Sep 2, 2014 | 05:52 PM
Flue's Avatar
Flue
Have you replaced the Engine Coolant Temp Sensor? The stupid thing tells the puter which mode to be in..closed loop or not. I have to replace the one in my ram...when it gets cold it will only run about 10 min before sputtering and not and stalling. At cruising speeds it likes to buck...that sucks.
My little 4 banger liked to belch white gas vapor from under the hood when the sensor finally failed.
