2nd Gen Durango 2004 - 2009
question about towing
Old Jan 22, 2015 | 04:51 AM
mikeyneon20mag@frontier.com's Avatar
Default question about towing
we have an 06 dodge durango limited with the hemi and factory tow package, with 3.55gears. we are wanting to buy a keystone passport thats around 35ft but only weights 6050lbs. ive got the wdh for it. I now the max with the gears is 7200lbs. does anyone see this being a problem. we really dont go that far to camp prob. around 35miles away.
Old Feb 23, 2015 | 08:44 PM
gojeepgo's Avatar
gojeepgo
Once you load the truck with people and gear and the camper with supplies your going to be right at or over the weight limit.
I have an 05 limited Hemi 3:55 gears. I tow a 21 ft hybrid starcraft that weighs about 4200lbs dry. I use a WD hitch and I know that thing is back there, especially in the hills. The rear of the Durango still sags a bit with the WD adjusted properly.
Old Mar 8, 2015 | 09:09 PM
outbackgeorgia's Avatar
outbackgeorgia
You will need a WD hitch with anti sway, like an Equalizer or Reese. You are at the limit, but should be fine if you don't overload the Durango. I tow a Keystone 25RSS Outback, have many thousands of miles with no issues, but a semi passing you will keep you awake! Mine is about 4500 dry, prob 6000 wet. Mine is a Hemi with 3.55, max I believe is 7100 lbs. you are starting heavy, so don' carry too much in the camper. 35 miles is nothing, esp if flat.
Dave
Old Mar 9, 2015 | 08:22 AM
I do have a WD hitch, and I added coil-rite air bags.
