2nd Gen Durango 2004 - 2009
ABS and Traction control light
Old Mar 13, 2016 | 06:40 PM
seymour1125's Avatar
seymour1125
Default ABS and Traction control light
Hello fellow Durango owner. I have a 04 Durango that i replaced to upper control arms on today. while i had it in the air i leveled the front end by tightening the bolts on the torsion bar keys. Everything rides a ton better with no clanking or bouncing when hitting bumps. getting ready to purchase 285/75/17s to finish it off but my problem as of now is the traction control light and ABS light is on. Any suggestions on what this could be?
Old Mar 13, 2016 | 07:28 PM
You either disconnected/damaged the speed sensor wiring or got the sensor out if adjustment.
Old Mar 13, 2016 | 08:13 PM
seymour1125
thanks do you know how i fix that problem?
Old Mar 13, 2016 | 09:45 PM
Well you gotta look at them to determine the exact problem before a repair technique can be presented.
