2nd Gen Durango 2004 - 2009
RERear axle seal 12 bolt cover 9.25
Old Mar 17, 2016 | 02:36 PM
pgtek's Avatar
pgtek
Default RERear axle seal 12 bolt cover 9.25
Hi Guys
I need to replace my rear axle seal on my 2004 durango slt
i order the seal an the bearing just in case i need to replace it.
i know for sure i have to open the rear differential housing and remove the locking pin and the "C" clip holding the axle.
My question is the bearing press on the axle or i stay inside the axle tube?
and the seal is mounted on the end of the tube?
or i need to remove the old bearing and collar to access the seal
i have no diagram of the axle construction
Thanks
Old Mar 19, 2016 | 06:24 AM
SteinerSellers's Avatar
SteinerSellers
I'm almost certain the 9-1/4 rear end is just your standard setup with bearing pressed in the tube and then seal pressed in the end.
Old Mar 19, 2016 | 10:50 AM
Moparite's Avatar
Moparite
Yes, The 9.25 has stayed the same for the most part since the 70's.
http://autopartmaster.com/en/?action...4&id_pic=29488
Old Mar 20, 2016 | 09:53 AM
pgtek's Avatar
pgtek
Default made my day
Thanks Guys for the replied
I was sure you would come up for helping me out
thanks a million
