2nd Gen Durango 2004 - 2009
07 Durango fuel problems
Old Sep 1, 2016 | 05:31 PM
Andrew Holfeltz's Avatar
Andrew Holfeltz
Default 07 Durango fuel problems
I have a 07 Durango w/ 5.7 hemi, my wife went to get gas and when she got in to leave the car wouldn't start. I towed it home with the truck and am now stumped. The car cranks but won't start. I started by replacing the 4.5 year old walmart battery, then the crank shaft sensor on a whim. I finally replaced the fuel pump relay and after the relay in started! It seemed to run okay that night although we didn't really go anywhere. The next morning it wouldn't start again. I tried switching out the relay again and no luck. I'm really hoping it's not the fuel pump because it's full of gas. Any help would be really appreciated! Thanks
Old Oct 9, 2016 | 06:40 AM
usmanovic's Avatar
usmanovic
Hi
how much has your car run.. do you use Gas from the same station and same octane no. or the same type always... were there any alarming signs on the dash board previously.. I would be glad if you could give some detail about your usage as it will be easier for everyone to understand and get a true picture.. I have a durango 2007 as well and its almost run 191000 kms...she is a beauty..:-) .. had engine signs and starting issues but no more...will wait for your reply brother
