2nd Gen Durango 2004 - 2009
Headlight Switch Removal
Old Dec 24, 2016 | 10:19 AM
jowens1126's Avatar
jowens1126
Default Headlight Switch Removal
I just got a 2006 Dodge Durango and the headlight switch is broken. How do you get it out to replace it? Does the trim panel just pop out? Are there screws somewhere im not seeing?
Thanks
Old Dec 26, 2016 | 03:19 PM
fdreano's Avatar
fdreano
Disconnect the battery.
Remove the two torque-head screws on the panel on the driver's knee bolster.... Pop the lower plastic panel off at the top.. CAREFULLY pop the LH side of the trim piece that sits vertically beside the radio.
Remove two Philip's head screws up underneath the curved part of the dash. CAREFULLY pop the large piece that surrounds the instrument cluster off working it out from underneath the radio trim. Disconnect the harness from the light switch...now three Philip's head screws should easily remove it..
