2nd Gen Durango 2004 - 2009
2006 Dodge Durango Battery Drain
Old Sep 26, 2017 | 12:57 PM
mwarchut's Avatar
mwarchut
Default 2006 Dodge Durango Battery Drain
Good morning
We have a 2006 Dodge Durango that has a battery drain issue. I did a test and during key off the vehicle is consuming 200mA. I tracked down the cause at the internal fuse block. Fuse 15, a blue 15Amp fuse, when pulled drops the draw down to 7mA. This fuse is marked in the manual as the Bluetooth, CMTC and Sentry Key Diagnostics. Now our Uconnect has stopped working previous to this issue so we assume the Bluetooth failure may be the cause of the drain. So my question is, is the Bluetooth integrated to the radio or a separate module. Has anyone seen this happen before and can validate this is the real issue?
Thanks
Mike
