2nd Gen Durango 2004 - 2009
antifreeze everywere
Old Feb 7, 2018 | 04:31 PM
rickcobb78's Avatar
rickcobb78
Default antifreeze everywere
i was sitting in park while my 2000 dodge durango was running in all of a sudden smoke started coming out of the engine when i lifted the hood antifreeze was evrywere none on the radiator left in right side of the engine mostly is this my water pump?
Old Feb 7, 2018 | 06:22 PM
gcburkett's Avatar
gcburkett
Sounds like something spring a leak all of a sudden. No sign on a hose leak. Put coolant back in and look for the leak with the engine running. That fan can blow coolant all over the place.
Old Feb 7, 2018 | 07:33 PM
rickcobb78's Avatar
rickcobb78
so I put water back in it and nothing out of the hose's but antifreeze started coming out around the water pump like the gasket wasn't there
Old Feb 7, 2018 | 08:41 PM
Time for a new one.
Make sure it isn't coming from around the timing cover. Also, there is a bypass hose underneath the a/c compressor, check that too before spending money.
