2nd Gen Durango 2004 - 2009
Durango fuel pressure
Old Mar 13, 2018 | 11:52 PM
Jrodpool's Avatar
Jrodpool
Default Durango fuel pressure
Hello, I have a 2005 Durango 4.7. It shows no fuel pressure at the rail but gas comes out the bleeder hose on the gauge. It will start but I cannot give it any throttle unless I spray starting fluid into the throttle body. I've heard of low pressure but why am I showing none on gauge. I can hear pump come on. It also cranks over funny and wants to pop like a backfire in the throttle body. Thanks
Old Mar 14, 2018 | 09:14 AM
primem's Avatar
primem
It sure sounds like you have a fuel pressure problem. fuel should not bleed out the fuel guage so try a different pressure tester.
Old Mar 14, 2018 | 11:55 AM
Jrodpool's Avatar
Jrodpool
the gauge bleeds out when I push the release valve on the gauge, but there is never any pressure showing on the gauge
Old Mar 15, 2018 | 10:42 AM
Jrodpool's Avatar
Jrodpool
Well I just replaced the fuel pump and have pressure. Its starts right up but when I accelerate it bogs down real bad and seems to have no power
Old Mar 15, 2018 | 09:30 PM
primem's Avatar
primem
not much to go on.... one possiblitity....whenever i hear bogging...i think clogged exhaust....check for backpressure with a gauge or unscrew the pre cat 02 sensors from the exhaust stream to allow the exhaust to bypass the cats.
