2nd Gen Durango 2004 - 2009
‘06 Dodge Durango Loud Engine Noise
Old Sep 12, 2018 | 08:19 PM
Stefanylambert's Avatar
Stefanylambert
Default ‘06 Dodge Durango Loud Engine Noise
Hi, My ‘06 Durango ran hot a few days ago....only while idling...it would cool down as I drove. .Took it to the mechanic and I was told that it was my clutch that was causing the problem and replaced it. I just picked up my vehicle from the mechanic and I noticed that the engine is extremely loud now. It seems like it’s lost a little power and the sound seems more like if you drop it to a lower gear sound. I checked the other gears just in case something may have happened and it is in the correct d location. It is shifting and seems to run a little smoother after a few minutes of driving and the faster I go.
I recently had my radiator and my thermostat changed a few months back
its a V6 2WD 356k miles
any suggestion as to the problem ?
Old Sep 12, 2018 | 09:23 PM
b1lk1's Avatar
b1lk1
Might be an extreme duty clutch so it stays engaged longer.
Old Sep 13, 2018 | 08:06 AM
Manual, or automatic trans?
