2nd Gen Durango 2004 - 2009
Ignition off clicking noise
Old Jan 31, 2019 | 01:14 AM
Robert42164's Avatar
Robert42164
Default Ignition off clicking noise
Got an 08 Durango, 4.7 V8. With ignition off and key removes the ADS relay is hammering. (Loud clicking) Doesn’t do it with the key on or running. It’s done it once before but stopped clicking after a few minutes, normal start and idle. This time it started as we were leaving the house to watch or son graduate. Running behind schedule so I assumed it would quit on its own like before. Received phone call later that evening, it in fact did NOT quit and has now caused the alarm to go off. And by the time we made it home the next evening had completely drained the battery. What’s yalls idea with this? PCM? Bad ground? Exposed wire? I’m stumped. I’m generally pretty good with this stuff but starting to doubt my self now
Old May 31, 2019 | 04:43 PM
slickdaddy96's Avatar
slickdaddy96
Mine did this when the sunroof drain tubes were clogged and water was getting into the wiring and interior fuse box area. It happened badly when it was raining then quit once dry.
I got a lot of electrical Gremlins now due to that happening for a while before I discovered and fixed the leak.
