2nd Gen Durango 2004 - 2009
How to replace transfer case motor
Old Feb 24, 2019 | 07:37 PM
DoubleAgent's Avatar
DoubleAgent
Default How to replace transfer case motor
How to replace transfer case motor I’m new to the Dodge Forum. Trying to replace the transfer case motor on a 2005 Durango 5.7 two speed transfer case. Everything is in the way I have the motor detached but can’t get it out. Any suggestions?
Old Feb 25, 2019 | 10:17 AM
Drop the front driveshaft off the t-case. Should give you enough room to pull it out.
Old Feb 25, 2019 | 11:47 AM
DoubleAgent
Thanks for the response. I dropped it but I can’t pull it out because the frame won’t let me pull it out of the way. I know it works on the Dodge ram but the Durango has obstacles at every point. The only thing I can come up with is supporting the transfer case with a jack and then removing The crossmember a few inches.
