2nd Gen Durango 2004 - 2009
04 dodge durango 2 generation 5.7 reset ECM ??
Old Aug 4, 2019 | 01:40 PM
BBICLBIC's Avatar
BBICLBIC
Default 04 dodge durango 2 generation 5.7 reset ECM ??
Yes i need help please .I thinking maybe to reset my ECM but not sure how too or if i need to . I went out 1 day to go and i could not get it out of park gear & ABS ,Brake & engine light came on in the cluster .And my speedometer & gauges all quit working .^ i have no brake light .This all happened all at same time .I did replace the brake switch still no power to brake lights .thanks
Old Aug 6, 2019 | 11:01 AM
Disconnect the battery for a while. 10-15 minutes.
Old Aug 6, 2019 | 03:27 PM
BBICLBIC's Avatar
BBICLBIC
Default Resetting the ECM
Do I unhook the + cable & - cable or what .? Thank you 4 the help .this Durango has me pulling my little bit of hair out .
Old Aug 7, 2019 | 09:31 AM
07DurangoDriver's Avatar
07DurangoDriver
Default Hair out
Disconnect the negative cable only for 10-15 minutes, then reconnect. That is a hard reset of the control modules on your vehicle.
All the things you describe are related to the instrument control module. They fail and must be replaced, expensive part and the dash is disassembled to do it.
Old Aug 9, 2019 | 12:17 AM
BBICLBIC's Avatar
BBICLBIC
Ok i will try that in a couple days .I had to take a break from working on it ,Bad back & bad attitude .I am going fishing for a few .Its good for me to walk away 7 breath .Thank you i will let you know if it fixes it pray pray .
Old Sep 9, 2019 | 01:19 PM
comsax1's Avatar
comsax1
Will this work on a 2010 Journey SXT 3.5?
Old Sep 9, 2019 | 02:42 PM
Yes. Will work for any vehicle.
Old Sep 9, 2019 | 07:24 PM
comsax1's Avatar
comsax1
thank you
Old Oct 3, 2019 | 11:42 PM
BBICLBIC's Avatar
BBICLBIC
well i disconnected the battery & also cleaned the inside fuse box C1 ,C2,& C3 plugs there were full of corrsion from the sub roof leaking ang guess the water goes in side the kick fuse box .Got everything to work .Except the dash cluster i reset it at least 10 times by pushing the dash button but it will not reset right >Any ideals ?thanks will
