2nd Gen Durango 2004 - 2009
Power Outlet
Old Sep 19, 2019 | 12:24 PM
Blake87's Avatar
Blake87
Default Power Outlet
My power outlet on the front dash has gone bad. Any recommendations on how to replace? And where to buy a new power outlet?
Thank you
Old Sep 19, 2019 | 01:53 PM
Dealer if you want to plug and replace. Otherwise, auto parts stores sell universal ones you will need to hardwire in.
Old Sep 19, 2019 | 02:52 PM
ol' grouch's Avatar
ol' grouch
You can also go onto Fleabay and get all sorts of replacements. Since I don't smoke, I've replaced some of the ones in my Escalade with USB charger ports. One even has a volt meter along with two charge ports.
Old Sep 19, 2019 | 03:18 PM
Blake87's Avatar
Blake87
I don’t smoke either. I just bought an FM transmitter so I could play music off of my phone and it won’t work in my car, I plugged it into another car and it worked just fine.
Old Sep 19, 2019 | 03:44 PM
Get a meter out and start testing for voltages at the outlet. Check the fuses as well.
Old Sep 19, 2019 | 07:16 PM
ol' grouch's Avatar
ol' grouch
Check the fuse. One of my outlets on my '02 wasn't working. I knew what happened. Back in 1976, my sister went to move my car. There was no lighter in the plug as I was using it to power my CB. She stuck the key in it and shorted the outlet. The fuse blows fast when you do that. Replaced the fuse on my '02 and the outlet works fine now.
