2nd Gen Durango 2004 - 2009
Aftermarket Stereo Install Questions
Old Jun 25, 2020 | 12:08 PM
benmorris's Avatar
benmorris
Default Aftermarket Stereo Install Questions
So I have an 05 Durango SLT, no Infinity sound, no steering wheel controls, no navigation. From what I've been reading, the factory CD player is a 1.5 DIN, plus the dash has the extra cutouts for the volume and radio tuner ***** on either side. I've installed several aftermarket stereos before in different cars, but I'm having a little trouble getting solid info on some things for this particular install. Here are some questions that hopefully you all can answer:
1. Will I need to modify the dash facade to fit a standard double DIN stereo? The Metra kit linked below seems to give a template for cutting out the dash to fit double DIN.
https://smile.amazon.com/gp/product/...=ATVPDKIKX0DER
2. Given that I don't have an upgraded sound system with steering wheel controls, is there a basic wiring harness I can get to just wire up a new head unit? I found this, but it indicates a required accessory module to retain the other functions, which I don't necessarily need.
https://www.crutchfield.com/p_794HRR...d.html?tp=3486
3. Besides soldering, is there a recommended way to do the wiring connections? Any preferred crimp connections or whatever?
Also, is there a better forum section I should cross-post this to? I'm new here. :-D
Thanks in advance for your help!
Old Jun 25, 2020 | 02:00 PM
Yes, use crutchfield. They will supply you with everything you need for plug and play.
