2nd Gen Durango 2004 - 2009
Bad mechanic timing job
Old Nov 21, 2020 | 05:25 AM
Christian Woodside's Avatar
Christian Woodside
Default Bad mechanic timing job
Ok this so called mechanic put the tensioner guides on my 4.7 up side down he lost the piston out of the tensioner so he tried to hide make it look its tight he tried to fix as u can see the tensioner came off cause not designed to go in that way how he did it still baffles me well how 🤔 anyway. Its put all back together now the right way and now im getting p0016 code crankshaft cam shaft collation code would this code be generated cause that timing chain was stretch premature?
Old Nov 21, 2020 | 08:23 AM
May be off a tooth.....
What's the engine in?
Old Nov 21, 2020 | 01:37 PM
Christian Woodside
4.7, 2006 dodge durango
Old Nov 21, 2020 | 03:34 PM
Gonna move this to the 2nd Gen Durango section for ya.
