2nd Gen Durango 2004 - 2009
04 Durango AC/heat will not turn on... pls help
Old Feb 20, 2021 | 12:23 PM
Kay.bell's Avatar
Kay.bell
Default 04 Durango AC/heat will not turn on... pls help
Hi.
I have an 04 dodge durango hemi 5.7L that I bought not too long ago, just to have an suv.
the ac and heat in the front will not work, the back cold air works and turns on but not the heat. But my main concern is the front.
so what I've replaced already. The blower motor resistor, the blower motor fuse (in the hood) all the fuses inside and out are good. Also I took out the blower motor and plugged it up and it spun. The wiring harness looked okay as well.
I can press the buttons for the air, and nothing happens (the blower motor doesn't turn on). It's like I'm not even turning it on. so I'm not sure what else I can do..
here are the codes.
1. Evaporator temperature sensor circuit high
2. Rear mode door travel range too large
3. Recirculation door control circuit open
4. Auxiliary coolant pump control circuit open
5. Infrared temperature sensor internal
6. Automatic temperature control system performance
7 multiple cylinder misfire
8. general evap system failure
9. Evap system small leak
10. Cooling fan 2 control circuit open
11. 02 sensor 1/2 heater performance
12. Fuel system 1/1 rich.
