2nd Gen Durango 2004 - 2009
Engine and gear upgrades.. 5.7
Old Feb 28, 2021 | 10:35 AM
UrbanaMechanic83's Avatar
UrbanaMechanic83
Default Engine and gear upgrades.. 5.7
my valves are failing, and so is my torque converter...
should I bore my block and upgrade the top end?
I heard something about the stroker motor will fit?
should I go with another torque converter, or should I go with a stall version? Would it be better to change the gears in the rear end, or in the transmission, or both? I have an 06 durango 5.7 2wd.
Old Mar 4, 2021 | 08:03 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
moving this to the second generation section for you
