2nd Gen Durango 2004 - 2009
Driver's side power window does not auto UP
Old Dec 30, 2021 | 07:56 PM
TFMoore's Avatar
TFMoore
Default Driver's side power window does not auto UP
Switches have been replaced and did not correct problem. Window goes up but not automatically.
Old Jan 17, 2022 | 11:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do this. The window may need to be programed. Roll the window down using the switch and hold the switch in the down position for 10 seconds and then roll the window up and hold the switch in the up position for 10 second. The auto window should be program by then. If it doesn't, May need to go to dealer and find out if there is any updates for the BCM.
Old Jan 18, 2022 | 08:46 PM
TFMoore's Avatar
TFMoore
Thanks - apparently it needed to be reprogrammed. It now works. Thank you.
