2nd Gen Durango 2004 - 2009
I need help with 2007 Dodge Durango liftgate actuator?
Old Sep 28, 2022 | 10:33 AM
ronald1981d's Avatar
ronald1981d
Default I need help with 2007 Dodge Durango liftgate actuator?
f
Hello and thanks for viewing. I need help with finding an 8 pin actuator lock for a lift gate for a 2007 Dodge Durango. Most of what I have found similar to the one I got/need comes in 6 and 7 pin. Will a 7 Pin connector work? The new actuator doesnt have some of the hookups that my old broke one has: the spring and the little wire that trigger the power when you open it manually. I have looked and looked but was unsuccessful in finding an exact match. Any information or alternate methods will be helpful. Thanks!
Last edited by ronald1981d; Sep 28, 2022 at 10:43 AM. Reason: forgot to write the problem down
Old Nov 7, 2022 | 01:56 PM
MannerMauler's Avatar
MannerMauler
What are the part numbers for both actuators?
Old Nov 7, 2022 | 02:01 PM
MannerMauler
The newer looking actuator seems to have a broken gear as well,
Old Nov 9, 2022 | 01:50 AM
ronald1981d
Thanks for your response. I had to go on ebay and buy an identical used one. This new one wouldnt work right with my wiring harness setup.
