2nd Gen Durango 2004 - 2009
High idle speed
Old Jun 6, 2024 | 01:31 PM
P0000's Avatar
P0000
Unhappy High idle speed
From a cold start, out of the blue, high idle speed. Replaced MAP, IAC, TPS, and air charge temperature sensor. Now starts with 1200-1500 RPM. NO CODEs. I test drive it and turn on Cruise Control as soon as I SET speed, it throws a check engine light and gives me the P0068 x2, my scanner says MAP/MAF Throttle Position Correlation. I've checked for Vacuum leaks with a spray bottle but the fan is moving so fact it blows most of it away.
