2nd Gen Durango 2004 - 2009
RUST??
Old Feb 18, 2006 | 10:16 PM
Firefighter251's Avatar
Firefighter251
Default RUST??
I have a 2004 Durango and have developed rust by the right side chrome piece on the hatch. I already had this repaired at the dealer once and has developed again in less than a year?
Anyone else experiencing this problem?
Also my rear step plate has turned almost to a white/gray color. I am assuming Dodge forgot an additive to the plastic resulting in the dicoloration.
[hr]
[sm=headbang.gif]
Old Mar 25, 2011 | 12:19 PM
CleverDurango's Avatar
CleverDurango
I have an 06 w/ the same issue, i have not had it repaired yet, but if i do i am not going to have it repaired by the dealership, i will be taking it to a body shop for professional work. I also have developed rust on the rear driver side fender under the gas cap.
Old Mar 26, 2011 | 12:53 AM
IndyDurango's Avatar
IndyDurango
There is a TSB on the rear step on your 2004 where they will put a new cover on there. Look into it. You are correct that the UV is breaking down the plastics.
IndyD
Old Mar 27, 2011 | 11:46 AM
pwee42's Avatar
pwee42
Yeah i have rust in the same spot.Had dealer fix inside rear door jam but now my warranty is out.I fear its just the beginning.
Old Mar 27, 2011 | 09:48 PM
n8ech's Avatar
n8ech
FF:
The spot on the right side of the rear hatch is common, as well as the rear most part of the s driver side rear wheel well.
My D is currently at my local Carstar to have rust behind rear wheel well fixed.
Indy:
What is the TSB number for the rear step plate? My 04 needs a new one of those also.
Don
Old Mar 28, 2011 | 12:30 AM
IndyDurango
I don't have it on file since it is a Gen2.
Sorry.
Old Mar 29, 2011 | 09:37 PM
hoon's Avatar
hoon
Originally Posted by n8ech
FF:
Indy:
Don
If you don't mind me asking, I'm just curious how much the rust on the wheel well is costing you to repair? I'm getting some bubbling there and I don't want it to get worse but I'd love to know what it would cost to fix in case I need to do it in the future.
