MODS???
Whos modded? What kind of difference can someone expect from a TB SPacer? What about the power pulley? This site is what i have been looking at http://www.rpmoutlet.com/ramhemip.htm
Throttle body spacer is a waste of money!, The power pully makes sense, go to DodgeTalk.com under 2gen Durangos performance page, there a company selling a brand new shipment, he says rated for 12.7 RWHP http://www.dodgetalk.com/forums/showthread.php?t=93954, this seems worth checking out, I have seen other members swear by these pulleys after they change them.
i am meber there also under same name. Thanks!!!!!
Well the throttle body spacer on some cars does work. On the D i don't know the ones i see look kinda cheesy. I have an 04 Impala SS and they work not so much for adding horsepower but it blocks hot coolant from flowing through the TB and heat soaking the TB and does not conduct heat which provides a lower IAT which could increase power to a point not significant but everything you can do to help cool the incoming air helps. The TB spacer was like an inch thick and made of some black not metal material that was cnc cut. Another good use for a spacer is a injection point for alcohol or NOS. I had alky injection on my imapal for a while and injected through an aluminum spacer.
