2nd Gen Durango 2004 - 2009
Torsion Bar Lift
Old Apr 30, 2006 | 12:58 AM
jasonwyo's Avatar
jasonwyo
Default Torsion Bar Lift
Just wondering if anyone has experienced any problems after they raised the front end of their Durango a couple of inches by adjusting the torsion bars and then having an alignment performed.
Old Sep 2, 2006 | 10:56 PM
mrjohnrobertmiller's Avatar
mrjohnrobertmiller
Default RE: Torsion Bar Lift
Bump....also...how much lift does it give?
Old Sep 3, 2006 | 01:17 PM
jasonwyo's Avatar
jasonwyo
you can only get 1 1/2 to 2 inches out of the lift
Old Sep 5, 2006 | 12:00 AM
mrjohnrobertmiller
Any alignment issues? How badly is the ride affected?
Old Sep 5, 2006 | 12:31 AM
jasonwyo's Avatar
jasonwyo
Not after you get it realigned. The torsion bar lift will roll the front tires out and wear the outside of the tire. The alignment will straighten the tire restoring the normal wear pattern. That is 1 1/2 to 2 inches is the max because of the need for realignment.
Old Sep 7, 2006 | 02:11 PM
mrjohnrobertmiller
What size tires can you fit? Any pics? So the torsion bar lift after the alignment will restore stock geometry?
Old Sep 19, 2006 | 05:17 AM
NvHemi's Avatar
NvHemi
You can do it that way but the ride will get very stiff. If you do the Truxx lift you can lift the front 3in and get the level ride and look but maintain your soft ride. With both you have to do a alingment after I have 285/70-17 on mine that is a 33in tall tire.
Old Sep 19, 2006 | 09:22 AM
jasonwyo's Avatar
jasonwyo
Are you running 3.55s or 3.92s.? Just wondering how much extra effort is seen to turn the larger tires.
